Morpho Material Library
Hello everyone,
I am a PhD student working on coupling Honeybee and Morpho to measure the heat exchange between the microclimate and buildings.
For my urban climate model, I need to assign building materials in the Morpho interface. However, I noticed that Morpho has a pre-defined library of materials in XML format with specific codes. I am wondering:
  1. Is it possible to modify the existing material properties in the Morpho material library?
  2. Can I create custom materials in Morpho that align with similar materials used in Honeybee?
I would greatly appreciate any guidance or suggestions on how to achieve this. If @AntonelloDiNunzio, @chris or others familiar with the Morpho interface could provide insights, it would be incredibly helpful.
You need to modify the materials within the envi met material editor, and then read in morpho the user library.
