Hi guys I am running an Incident Radiation Analysis, I used Legend Parameters tool to move and scale the legend, but I haven’t found how to move analysis titile, thus Incident Radiation overlaps with the drawing, also because building is not orthogonally oriented.
Is there any way to move and rotate analysis title?
Not exactly what you’re looking for, but I slightly edited the code in the LB spatial heatmap component to take wider geometry to put the legend and title around.
I’ve added a _contextmesh input for the wider geometry you want the title and legend around
Adjust Heatmap For Context.gh (43.3 KB)
Hi Charlie,
thanks for your reply, I will try
