Posting a following up question to this post: Surface Temperature under reflected solar heat gain
A clarifying question for my understanding…using the componentSolarMRT, we plug in the DIRECT solar rad from the weather file and unobstructed direct solar irradiance. For the DIFFUSE solar rad, we take the difference b/w the reflected irradiance on the calc surface and the direct solar irradiance with no obstructions. the different makes sense because we are finding the delta MRT due to the solar reflection. just need some clarity as to why the reflected rays find its way into the diffuse component - do we account for the sky’s original diffuse radiation in the radiance PIT calc then add the reflected rays as additional diffuse?
Given the above, what does the deltaMRT represent?
Attached is the script I am referencing. thanks to @chris
PIT_SolarAdjusteMRTExample.gh (551.5 KB)
