I am using Envi-Met to study the effect of nearby tree shadowing and evapo-transpiration on the temperature of houses. I wanted to create different zones(rooms) in the house to get a more detailed result. However, after creating the zones in Grasshopper using Honeybee tools, i was unable to generate the building with the interior walls in Envi-Met Spaces. Are there some particular steps that i should be doing prior generating the design in the latter format?
Hello, I want to know what kind of workflow is this envi-met and honeybee joint simulation? Is the zone created in honeybee and then imported into envi-met for simulation? What is the specific step? Can you refer to related tutorials or papers?
thank you very much!
Yes, its a joint simulation using Envi-Met and Honeybee. I am creating the design using Honeybee and then exporting the design into the format used by Envi-Met. I wanted to create a house with different rooms and internal walls however, the wall are not appearing after generating the .inx file used in Envi-Met.
unfortunately Envimet does not consider internal walls yet, it can give you accurate results on facade. It remove internal walls before calculation running.
