Multiroom model uses the same program for all rooms
I’ve set up a multiroom model, with different programs/set points for the different rooms. E.g. one zone is kept at the temperature of only 10°C, others at 21°C. When I use the HB Label Rooms to check all the settings in my model, the setpoints are all correct. Yet, when I calculate the model, it’s clear that all rooms are using the same program/set points. For some reason the programs I’ve set are being overwritten by one single program. I’ve tried playing with flattening/grafting at certain points, nothing works. When I simulate the rooms separately, it’s calculated correctly. The moment I have model with multiple rooms, the programs get overwritten.
Hi @tvanbesien
The best way to see whether your program is assigned to your needs is to check the produced IDF for each zone/space/room. You can have some try and error to reach your final setup. Additionally, using HB Rooms by attribute exactly before when you finalize the HB Model shows the programs as well.
