You can try updating to latest version of LBT 1.5 and try again.
Tried the latest version 1.5
still not working ok thank you my friend
Last you can try reinstalling the full plugin using oneclick installer fromm pollination website. This is the last thing you can try or else it may be a bug !
Thank you very much for your reply, I would like to ask whether to reinstall ladybug in food4Rhino?
You can download the grasshoper plugin oneclick installer here
Thank you very much for your help I will try it
Hello! I still haven’t solved this problem, unfortunately I can’t help you
Thank you very much for your reply, the HDR image is able to upload, but it turns red when connecting to imageViewer via falsecolor.
I was thinking if you could upload the HDR file here in a message so I can test it myself.
Thank you very much for your help I am mainly wondering why my falsecolor run is wrong As for the final run and the plot result is not very important, thank you again for your generous help.
Hi Mikkel,
@mikkel
Really appreciate your help.
Here is my HDR.
west4_h_label.HDR (1.4 MB)
And Error shows “Solution exception:None zero return code: 2”
Hi @Silash,
There is nothing wrong with your HDR image. Have you tried to update your core libraries and components to the newest version? If that does not solve the issue, please open the component and run it as shown below and report the full error message that you get.
Hi @Silash,
Can you confirm that you tried the following?
Can you try add the two lines (209 and 211) as shown in the image below. Please run the component with those lines and report the output again.
