I gave my students a honeybee-radiance file that worked perfectly fine on my computer, however two of them had the same error, illustrated below. The simulation runs without errors however the results are 100% daylight factor for all the room, instead of the supposed distribution. Any suggestions?
This is likely because the Units in Rhino is millimeters. Change it to meters. Because of the units the grid is probably outside the building hence why it shows 100% DF.
