I’ve tried so many parameter permutations that I’m losing my mind!
I cranked _ad_ to 10000 and _as_ by at least half that, but same problem.
Current “not highest, just trying to get rid of this problem” parameters are:
_quality = 1
pt = 0.1
ds = 0.25
aa = 0.15
pj = 0.9
dt = 0.25
ad = 512
dj = 0.5
dp = 256
lw = 0.01
xScale = 2
yScale = 2
ar = 128
as = 256
dc = 0.5
av = 0
lr = 6
ps = 4
st = 0.5
sj = 0.7
dr = 1
ab = 8
PS: What is the -c parameter talked about on this page?
I can’t seem to find that documented elsewhere.
Should it be passed into additionalIP_?
What should the ranges be?
EDIT: from these docs posted by @sarith , is -c the pcomb parameter?
Hi Joe, can you try -ab 3 -aa 0.05 -ar 1024 -ad 1024 -ps 1 -x 300 -y 300 in additional parameters and see if it improves anything? If it does, you can crank up the resolution -x 1000 -y 1000 and set -ps 2 in the next run.
If it doesn’t change anything, I’d probably have to look into the model to figure out what is going on. The discussion on rcontrib is not relevant to what you are doing (your simulations are not pure Monte Carlo).
(PS: I wont be able to look into this at least tomorrow afternoon)
Ok… those parameters did keep it from failing during a luminance _simulationType_ this time. However, the results were roughly the same (spotty light problem).
I figured it must be something with my geometry, since some of it was just imported and not optimized. So I stripped the office of nearly everything, except the shell, glazing, and outside ground surface. But looks like I still have the same problem with default RADParameters and _quality of 1.
Here is all the information I can think to give to debug it. Let me know if there is anything else I can help with.
I am by no means an expert at Radiance tool chain (obviously), so this probably doesn’t mean much, but I noticed differences in the cmd line parameters in the first rpict call vs the 8 separate core calls. Here are captures of the cmd line parameters when it kicked off with default RADParameters + _quality 1 + those additionalP_ above.
The first calc preps up the simulation by creating an ambient file. So, thats fine. More details here. And if you want to get further indepth info, see this (do a text search for “overture”).
With regards to the spotty light thing, the issue is that your surfaces are specular (when they shouldnt be).
If you set the values for “spec” to 0 in your plastic materials (I guess its grass?), it will work out fine.
mod plastic id
0
0
5 red green blue spec rough
So… looks like it’s the materials I used. Either the way I’m using them or they are too reflective. If I remove the setRADMaterials component where I specifiy materials, the results are fine. If I change the order of setRADMaterials and addHBGlz it doesn’t make a different; the problem still exists. So it is likely the material of the wall is too reflective…
