HUAYACOCOTLA FINAL.3dm (407.0 KB)
HUAyaCOCOTLA FINAL.gh (853.3 KB)
Hi there, my boss asked for the airFlorVolume of a room that I modeled in Rhino, but I cant have the result after running and connecting the readEpResults into the exportToOpenStudio. What can I do?
Legacy version (the one you are using from the above images) doesn’t support AFN.
You need to go for LBT.
Hi there, I want to read the AirFlowVolume in the HB Result component. But there is none Result component can read AirFlowVolume in HB1.6.0. So how can I read this result? It’s very important for me!
which component can I use to read AirFlowVolume? and how? It’s urgancy.Thanks a lot.
Hi @maoyimo
Here is a sample file for you to generate custom EP outputs:
GenCustomEPOutputs.gh (38.2 KB)
