Hi I am trying to create a simple energy model for a 4 storey Building. I get results when I run these 4 floors separately. But when i use solve adjacencies to create one single building it does not give me cooling and heating outputs. I have checked for non-convex surfaces.
I am attaching a gh file with internalized geometry. Hel
This is the error message.
{0;0;0}
- Current document units is in Meters
- Conversion to Meters will be applied = 1.000
- [1 of 8] Writing simulation parameters…
- [2 of 8] No context surfaces…
- [3 of 8] Writing geometry…
- [4 of 8] Writing Electric Load Center - Generator specifications …
- [5 of 8] Writing materials and constructions…
- [6 of 8] Writing schedules…
- [7 of 8] Writing loads and ideal air system…
- [8 of 8] Writing outputs…
… idf file is successfully written to : c:\ladybug\NTS805\EnergyPlus\NTS805.idf - Analysis is running!..
Done! Read below for errors and warnings:
- Program Version,EnergyPlus, Version 8.9.0-40101eaafd, YMD=2018.05.31 14:40,
- ************* Beginning Zone Sizing Calculations
- ** Warning ** ZoneHVAC:IdealLoadsAirSystem “NTS_FLOOR_1 IDEAL LOADS AIR SYSTEM” Requested outdoor air flow rate = 1.02970 [m3/s] exceeds limit.
- ** ~~~ ** Will be reduced to the Maximum Cooling Air Flow Rate = -99999.00000 [m3/s]
- ** ~~~ ** During Sizing, Environment=LOUISVILLE BOWMAN FIELD ANN CLG .4% CONDNS ENTH=>MDB, at Simulation time=07/21 24:00 - 24:10
- ** Warning ** ZoneHVAC:IdealLoadsAirSystem “NTS_FLOOR_2 IDEAL LOADS AIR SYSTEM” Requested outdoor air flow rate = 1.02970 [m3/s] exceeds limit.
- ** Warning ** ZoneHVAC:IdealLoadsAirSystem “NTS_FLOOR_3 IDEAL LOADS AIR SYSTEM” Requested outdoor air flow rate = 1.02970 [m3/s] exceeds limit.
- ** Warning ** ZoneHVAC:IdealLoadsAirSystem “NTS_FLOOR_4 IDEAL LOADS AIR SYSTEM” Requested outdoor air flow rate = 1.02970 [m3/s] exceeds limit.
- ** Warning ** ManageSizing: For a plant sizing run, there must be at least 1 Sizing:Plant object input. SimulationControl Plant Sizing option ignored.
- ************* Testing Individual Branch Integrity
- ************* All Branches passed integrity testing
- ************* Testing Individual Supply Air Path Integrity
- ************* All Supply Air Paths passed integrity testing
- ************* Testing Individual Return Air Path Integrity
- ************* All Return Air Paths passed integrity testing
- ************* No node connection errors were found.
- ************* Beginning Simulation
- ************* Simulation Error Summary *************
- ** Warning ** The following Report Variables were requested but not generated – check.rdd file
- ** ~~~ ** Either the IDF did not contain these elements, the variable name is misspelled,
- ** ~~~ ** or the requested variable is an advanced output which requires Output : Diagnostics, DisplayAdvancedReportVariables;
- ************* Key=*, VarName=COOLING COIL ELECTRIC ENERGY, Frequency=Hourly
- ************* Key=*, VarName=CHILLER ELECTRIC ENERGY, Frequency=Hourly
- ************* Key=*, VarName=BOILER HEATING ENERGY, Frequency=Hourly
- ************* Key=*, VarName=HEATING COIL TOTAL HEATING ENERGY, Frequency=Hourly
- ************* Key=*, VarName=HEATING COIL GAS ENERGY, Frequency=Hourly
- ************* Key=*, VarName=HEATING COIL ELECTRIC ENERGY, Frequency=Hourly
- ************* Key=*, VarName=HUMIDIFIER ELECTRIC ENERGY, Frequency=Hourly
- ************* Key=*, VarName=FAN ELECTRIC ENERGY, Frequency=Hourly
- ************* Key=*, VarName=ZONE VENTILATION FAN ELECTRIC ENERGY, Frequency=Hourly
- ************* Key=*, VarName=EARTH TUBE FAN ELECTRIC ENERGY, Frequency=Hourly
- ************* Key=*, VarName=PUMP ELECTRIC ENERGY, Frequency=Hourly
- ************* Key=*, VarName=ZONE VRF AIR TERMINAL COOLING ELECTRIC ENERGY, Frequency=Hourly
- ************* Key=*, VarName=ZONE VRF AIR TERMINAL HEATING ELECTRIC ENERGY, Frequency=Hourly
- ************* Key=*, VarName=VRF HEAT PUMP COOLING ELECTRIC ENERGY, Frequency=Hourly
- ************* Key=*, VarName=VRF HEAT PUMP HEATING ELECTRIC ENERGY, Frequency=Hourly
- ************* Key=*, VarName=ZONE VENTILATION SENSIBLE HEAT LOSS ENERGY, Frequency=Hourly
- ************* Key=*, VarName=ZONE VENTILATION SENSIBLE HEAT GAIN ENERGY, Frequency=Hourly
- ************* Key=*, VarName=ZONE VENTILATION STANDARD DENSITY VOLUME FLOW RATE, Frequency=Hourly
- ************* There are 1 unused schedules in input.
- ************* There are 1 unused week schedules in input.
- ************* There are 3 unused day schedules in input.
- ************* Use Output:Diagnostics,DisplayUnusedSchedules; to see them.
- ************* EnergyPlus Warmup Error Summary. During Warmup: 0 Warning; 0 Severe Errors.
- ************* EnergyPlus Sizing Error Summary. During Sizing: 5 Warning; 0 Severe Errors.
- ************* EnergyPlus Completed Successfully-- 6 Warning; 0 Severe Errors; Elapsed Time=00hr 00min 22.52sec
NTS_EnergyBalance - Copy.gh (776.9 KB)
