Hi, everyone.
I am trying to create the sun path diagram, and I found some online video and follow the steps. However, there is no way for me to change the sun points to spheres, only crosses. I tried different type of connection, and change color either the scale of spheres, but it still not working. I am using gh 1.7.0.
I cannot post my pannel as new account.
Hey @Astrid ,
The display point flavor is a Grasshopper setting. Just go to Display > Preview Point Flavor.
I personally like to use dot over cross, which is probably closer to what you want with spheres. Note that you can also connect the sun_points
to a native Grasshopper Sphere component if spheres are actually the thing that you wnat.
Thank you Chris!
I tried the settings, and the positions are correct, and I tried larger radius because the unit of my model is millimeter, when I change the radius to 4000, it finally showed the sphere
