No Visualisation on incident radiation simulation
I am trying to visualise how much energy each facade is getting using the incident radiation component, however, when I run the simulation the visualisation doesn’t appear to be working. Does anyone have any recommendation or fixes for this? Thank you in advance.
I’ll start hiding the Mesh component. and set the offset input to some value that fits the working units.
Since the legend has a range of values probably the geometry is hiding the resulting radiation mesh.
I want to utilise Honeybee however my buildings are in mesh form. There are many openings in my mesh. What methods should I use to convert the Mesh into a Brep?
