Good day everybody !
I am new with the Ladybug-Plugin. I am missing the 6 | Developers and the 7 | WIP section. I would like to try the Shadow Study and Shading Mask II node. I am using Rhino 7 with Ladybug 1.4.
Greetings
Greetings
Hi @Eruheran ,
Those components are Legacy ones, which are deprecated now in Rhino 7. Also, as the name “WIP” implies, those components never really worked well. Is there any reason why you couldn’t achieve the same result by running Direct Sun studies with a really fine _grid_size or Sky Masks with a really high _density_?
This is going to be a lot more reliable than trying to use those Legacy components.
