I don’t know if this is a easy to solve issue, but did anyone have any luck with the error coming from the nodes?
Not that I know the answer but I hope someone else can help you if you share more information about the version of Dynamo and Revit.
I was using Revit 2020 + Dynamo Core 2.3.0.5885 / Dynamo Revit 2.3.0.6270
This is the current setup, I try to follow the setup from the example file and was have similar trouble with the error message from site locator. Similar error found earlier (Invalid literal for float(): DynamoForRevit)
