Hello everyone!
I recently ran into a problem in a energymodel I am building, I was wondering if anyone could give me some insight on why energyplus is classifying this zone as non-convex. The model I’m building had diferente wall constructions and adjacent rooms (this explains why the wall geometry is so broken up), but i took those out to simplify. What I could figure out is if you remove one of the windows, energyplus doesn’t detect any severe errors.Example.gh (543.3 KB)
Vini
By checking the error message I could find the surfaces that EnergyPlus is complaining about:
and if you have a closer look you will see that the surface is slightly off! I draw a line between the start and end points of the wall with the window and then zoomed in. It’s minor and shouldn’t be something for EnergyPlus to complain but it does!
That’s strange! The gap between both surfaces was smaller than the Rhino tolerance (0,01 m). Ayway, I fixed the surfaces and that solved the error.
Thanks for the help!
Vini
