Hello, I would create an external roller shade double-controlled (temperature and solar radiation setpoint) to take into account its effect on indoor environment in energy simulations. I keep getting the following errors:
- Solution exception:‘NoneType’ object has no attribute ‘split’
- Type conversion failed from Goo to Brep
Hello! it looks like you mixed in a legacy component here:
replacing it with the updated version of the component should solve the issue I believe.
I think you are looking for this component if I’m not mistaken:
Actually I think your looking for this since it has the control types and other inputs from the legacy component you were using:
