Hello everyone, I´m having a problem with a file that doest break before, the error when I run "runenergysimulation"says:
- The simulation has not run correctly because of this severe error:
** Severe ** CheckWarmupConvergence: Loads Initialization, Zone=“ZONA_HABITABLE_3” did not converge after 25 warmup days.
I found this problem in this forum, but it doest have solved.
If I check the run error.err file i got this phrase:
Severe ** Problem in interior solar distribution calculation (CHKBKS)
** ~~~ ** Solar Distribution = FullInteriorExterior will not work in Zone=ZONA_HABITABLE_57
** ~~~ ** because vertex 1 of back surface=ZONA_HABITABLE_57_SRF_5 is in front of receiving surface=ZONA_HABITABLE_57_SRF_8
** ~~~ ** (Dot Product indicator=14.2205)
** ~~~ ** Check surface geometry; if OK, use Solar Distribution = FullExterior instead.
In other post said that this problem is not mandatory, I mean, I can get the result with this warming, but I haventt.
I attach the file: Duda.zip (891.4 KB)
Thanks for your help.
