Not subtracting glazing from wall
I,v problem with not subtracting the glazings from walls in with addHBGLZ in the attachment file. What’s wrong in my file?
honeybee tutorial 005.gh (533 KB)
Salam Arbab! :slight_smile:
You forgot to internalize the glazing geometry so I can’t reproduce the problem. Also please put a note inside the file where you exactly have the issue.
Mostapha
Ali,
I updated to the latest version and put in my own geometry and everything seems to be fine. If it’s a problem with your geometry, you need to make sure that you internalize the brep geometry or provide your Rhino 3dm file.
-Chris
honeybeetutorial005CWM.gh (529 KB)
