Hello everyone,
I am currently working on an optimization study using Octopus in Grasshopper to analyze how two parameters affect EUI (End Use Intensity) values. However, I am facing an issue when trying to connect the End Uses output from HB End Use Intensity to Octopus.
System Information:
- Rhino 7
- Grasshopper
- Ladybug & Honeybee (Latest Version)
- Octopus (Latest Version)
What I am trying to do:
I am using Octopus to optimize two parameters and analyze their impact on EUI values. To do this, I need to extract numerical results from HB End Use Intensity, particularly the End Uses output, and use them as fitness values in Octopus.
However, when I try to connect the End Uses output to Octopus, I encounter an error, and the values do not seem to be processed correctly.
Specific Questions:
- How can I properly connect
HB End Use Intensityoutputs to Octopus for optimization? - If the
End Usesoutput is not in the correct format, how should I process it to make it usable as an Octopus fitness value?
Best
Juhyung Lee
20250205_3.gh (123.7 KB)
250205.3dm (542.3 KB)
