Hi Busy-bees!
I’m trying to run a daylight simulation on a single floor for a building (attached). My problem seems to be limited to the analysis recipe of an annual simulation as the error I get disappears when I use a different recipe like daylight factor, or if I use the zones prior to solving adjacency. There well be an issue in my matching, but I cannot find an issue. The thermal sim works fine. The below is my set up specific to the daylight:
“1. Solution exception:unsupported operand type(s) for +: ‘str’ and ‘NoneType’”
Sharable.gh (917.3 KB)
Any help would be appreciated. Thanks!
