Open studio has something called Measures to compare different systems or designs.
Does ladybug tools support downloading and applying open studio measurs?
Do you have some tutorials how it can be done ?
On Macos, is it required to buy Rhino or other tool to use your tools?
Is it possible to import and use your tools as Python libraries, without Rhino or Grasshopper and is there a clear comprehensive tutorial about this ?
Hi @alaa,
In the honeybee energy tab you will find a component called “HB load measure”. (1)
When attached to the folder containing the measure it will load the measure and automatically shows its inputs. (2)
You can attach this to “HB model to osm”.
