Hi guys,
I have installed OpenFOAM v1806+ on Windows 10 home version. All the processes seem like OK.
OpenFOAM 1806 is working fine but I get the error below with the BlockMesh component.
- Solution exception:Failed to find container id.Do you have the OpenFOAM container running?
You can initiate OpenFOAM container by running start_OF.bat:
C:\Program Files (x86)\ESI\OpenFOAM\1612\Windows\Scripts\start_OF.bat
