Hello !
After downloading some definitions from Hydrashare from 2 years ago, I realized that LB Sync does not really work, supposedly because so much has changed. Is it the case that I have to manually find new nodes and replace to make it work ?
Hi -
You can’t mix components from the legacy versions of Ladybug with those from the LBT 1.x version.
The legacy versions have their own components to update older 0.0.x components.
-wim
