Hello, I have a question that I would like to ask. After I installed OpenStudio, I found that it can’t be used and the following problem appeared. Does anyone know why
- The simulation has not run correctly because of this severe error:
** Severe ** [ZoneHVAC:EquipmentList][1_0 Equipment List][equipment][0][zone_equipment_heating_or_no_load_sequence] - Value type not permitted by ‘type’ constraint. - The simulation has not run correctly because of this severe error:
** Severe ** [ZoneHVAC:EquipmentList][1_0 Equipment List][equipment][0][zone_equipment_object_type] - “Air Terminal Single Duct Uncontrolled 1” - Failed to match against any enum values. - The simulation has not run correctly because of this severe error:
** Severe ** [ZoneHVAC:EquipmentList][1_0 Equipment List][equipment][1][zone_equipment_object_type] - “Zone HVAC Low Temperature Radiant Variable Flow 1” - Failed to match against any enum values. - The simulation has failed because of this fatal error:
** Fatal ** Errors occurred on processing input file. Preceding condition(s) cause termination.
