OpenStudio-ERI - Energy Rating Index (ERI) calculation via OpenStudio/EnergyPlus
Hi @bwatanabe @chris I tag you for your post [HPXML to OpenStudio]
I worked on my model using openstudio application and now I need to calculate the Energy Rating Index. researching on the internet I found OpenStudio-ERI, but as far as I understand the input is hpxml, so researching I found OpenStudio-HpXml. now in openstudio-application i copied the measures from the github repository to the measures folder in openstudio and i got the following error
how should i install the measure. any guidance please.
Hi Diego,
I haven’t tried anything like going from OS to HPXML with my own model. I’ve only been exploring existing HPXML models and then opening them in OS. I bet if you post your question on Unmet Hours you might get some traction there.
Wish I could help you more.
Cheers,
Brent
