Hi All,
I’m receiving an error through OpenStudio which I haven’t seen before, and hoping someone here can help diagnose the causation?
Attached is an internalised script for a shoebox model intended to assess the impact of adjustments to a typical facade module. I’m certain that it is this bespoke module shading that is causing the error message (pasted below) which is leading to a severe error that prevents the simulation from proceeding.
- The simulation has not run correctly because of this severe error:
** Severe ** CalcCoordinateTransformation: Invalid dot product, surface=“Mir-SHDSURFACE_10_1”:
Any insights and potential methods to overcome this are greatly appreciated.
Many thanks,
James
66_SLR PEAKSOLARGAIN_int.gh (904.4 KB)
