I am trying to run the OpenStudio Measure ViewData by using the optional input “viz_variables” in the function to_openstudio_osw.
However after running the .osw and .idf I don’t see the .html file. Any ideas how to make the measure work?
Thank you.
Thank you.
Hey @tobiaspedersentsp ,
The View Data measure is a reporting measure so you need to make sure that you’re running the OSW in a way that runs the entire energy simulation (without the -m option). If you do this, the simulation should run to completion and you should get a html report provided that you specified correct inputs for the measure.
