Hi all. I am trying to generate number of OSM file using HB Model to OSM component and later run all the OSM file using HB Run OSM component. Along with this I also wanted to add a OS measure giving an OS simulation output at the end. But when I am connecting the measure and trying to create OSM files, it running simulation directly even if value 2 is given as input in “run”. On other hand If I am not using measure it is successfully creating OSM files. How can I create OSM file keeping measures applied.
I have attched both the file and the measure that is creating probelm
Reporting.rar (1.0 MB)
