Hi! I tried the OpenStudio to gbXML component multiple times. It says the file is exported to the file path but the folder is empty. Can someone please help me?
Not sure if this answers your question but if you toggle ‘openOpenstudios’ to True: from the OS app you can export as GBXML: convert/open in WUFI passive or whatever other GBXML interoperable sw that is your target
Thank you for your reply but I have already done that. The gbXML output is not appearing in the file path folder.
