Dear all:
I am trying to install Ladybug and I get an error when running OpenStudio. “1. Solution Exception:The type initializer for ‘OpenStudio.OpenStudioModelCorePINVOKE’ threw an exception.”
I’m not a programmer, because what I’m having trouble with is being able to troubleshoot it.
I’ve installed the latest versions of everything (OpenStudio, Radiance, Therm), in C:\NsersUsuario’sug_tools.
If you absolutely have to use the Legacy Honeybee plugin, then you need to use OpenStudio 2.9.1. Uninstall your current OpenStudio and install 2.9.1. Here’s the link to 2.9.1:
If you are ok not using Legacy Honeybee, I would recommend switching to the LBT 1.2 plugin since there’s no more PINVOKE errors in that plugin and you can use the more recent versions of OpenStudio.
