Hi @Hamzajh19, @MingboPeng , @LittleBuddha, @sarith, @LiamRuvio, @Grasshope
First of all, sorry to bother you, but I’m hoping someone can shed some light on this.
I’m evaluating glare risk from a glazed façade. In my study, drivers act as receptors and the glazing is the glare source. I’ve already identified when and where glare is geometrically possible. The goal now is to select a glazing that mitigates glare risk, so I need to vary the glass reflectance and transmittance. I find this second part rather challenging.
I’ve been using the Glare Hazard plot and the SGHAT manual from Sandia, but my results don’t seem consistent. I’m modeling the driver’s viewpoint as a point with a sight vector.
From the Glare Hazard plot, I’m using the retinal irradiance thresholds; above 0.1 W/cm² there’s potential for after-image, which I’m treating as my limit. This corresponds to 12.5 W/m² of corneal irradiance (incident at the eye). However, when I run an annual radiation analysis with Radiance, it’s strange that values below this threshold are rare, does this imply a constant risk of after-image whenever the source is visible?
This is confusing, and I haven’t found a single indicator in Ladybug to quantify this. DGP is intended for discomfort glare in offices and doesn’t seem suitable for outdoor glint/glare, which is more of a safety (disability glare) issue.
I also found the 20,000 cd/m² source luminance limit in EASA guidance. How can this be measured in LBT? A fisheye rendering yields many pixels with different luminances; if I simply take the maximum when the source is visible, it often exceeds this value.
Has anyone addressed this? Which standards or reference criteria are you using for assessment?
Thanks
