Hi everyone!
I’m working on outdoor MRT values obtained through Honeybee and Ladybug. When I run the simulation, it concludes successfully, even if it gives some warnings about the position of ground surfaces (it says that they are under the ground level). I’ve tried moving these surfaces upward, but nothing. The errors still remain.
Could someone run the simulation and check if you have the same errors on your computer?
Thanks really!
Cristina
https://drive.google.com/open?id=11DdXNxw0Hc5beKGiLbL70cFhhTdNS_Qn
