I wnated to update my Outdoor_solar-temperature_adjustor component, so I downloaded it from Github and delete the old one and simply drag and drop the new one into the canvas, but a message up in Rhino appears (attached screenshot) that my User object file is corrupt and it doest work, doesn´t appear in the LB
Glad that this all worked out. Mostapha, do you think that this was an issue with downloading that just happened to affect the solar-adjusted temperature component or there was something specifically problematic about the solar-adjusted temperature component? As far as I can tell, it seems like the former but let me know otherwise.
First, thanks for the fantastic components. And the thing with dowloading… first I tried it through right click and save as(on the github, it was dowloaded without problem)but this files desn´t worked (corrupted) , than I downloaded it from Mostapha from here just clicking on it, and than I dowloaded the whole bunch of components from github again but now I opened each one and clicked on RAW… and they are working now.
