Output Diagnostics
I’m trying to run a simulation but receive a warning that I have 15 ‘nominally unused constructions in input’. The warning suggests that I use Output:Diagnostics,DisplayExtraWarnings; to find out more information about these unused constructions.
How do I use this? I assume I need to create a panel with the string “Output:Diagnostics,DisplayExtraWarnings;” but I haven’t a clue where to point it.
Can someone please assist?
Craig
Hi @craig_w, you should be able to use the add_str_ input to add the Output:Diagnostics,DisplayExtraWarnings to the file when its ran again
Wonderful! That worked for me, thank you :slight_smile:
