Hi there,
I’m learning to use the Read EP surface Result, but the component seems to lose the output. Can anyone figure out what the problem is?
And my file is attached here.
read EP Surface Result…WH.gh (574.5 KB)
Hi there,
Without checking your file please check you are using the EPOutput component and if so you set any input on it.
Do you mean I should use the RunEnergyPlus instead of ExportToOpenStudio?
By the way, when I use the RunEnergyPlus, the ReadEPSrfResult still can’t work well, the error is here:
Thanks.
No. I meant the HB_EPOutput component, where you set the outputs you want to calculate.
You can upload your file here so people can help better.
sorry for miss your meaning, I have found where my problem is. thanks Abraham!
I have the same problem. Have you solved it? How is it solved? thank you
