Hi All,
I’m running some outdoor microclimate analysis and facing an issue at the end of the simulation when I run Honeybee_Mircroclimate_Map_Analysis. The outdoor Comf Matrix is not being calculated correctly. I get very little comfort (0.9. 0.7…etc) where I’m expecting much more.
Note: I’ve altered the comfort levels in ladybug-ladybug component earlier to be up to 32 degrees, and everything was corresponding well in previous iterations.
Not sure what could be causing this?
