Hello everyone;
I read what Chris had suggested about simulating PCMs and trying to do it. I got some errors. Here is the file.
http://www.grasshopper3d.com/group/ladybug/forum/topics/possibility…
Thank you
PCM.gh (597 KB)
Hello everyone;
Thank you
PCM.gh (597 KB)
Hi Amir,
In addition to the string you plugged into additionalStrings, you’d have to define a few more E+ classes for the simulation to run correctly.
Specifically:
HeatBalanceAlgorithm - the Algorithm must be set ConductionFiniteDifference
an additional Class:
HeatBalanceSettings:ConductionFiniteDifference(If I remember correctly, the default settings were fine)
I coded some components that automatically concatenated these strings, but I can’t remember where I placed them. I’ll see if I can find them.
Found them.
I haven’t touched them in a long time but I think they still work.
Do note though that I did those as an exercise/attempt to understand the legacy code so they’re not fully integrated into HB.
sample_outdated.gh (66.5 KB)
