Photopic lux for view point
I am trying to make a script in grasshopper to calculate the photopic lux for a particular view point in the room. I am considering only artificial lighting for this research.
Purpose of research- To calculate various photopic lux as I change the distance between the lighting fixtures and the view point.
I have made the script and connected all grids to the analysis part but I am facing problem of calculating my results. I have attached screenshot of some part of the script and also my ‘.gh’ file along with the discussion.
Thanks for any help!
box script2.gh (535 KB)
Hi Anmol,
I think the geometry in your gh file is not internalized. Can you share the rhino file, and your IES file, as well?
Sarith
Thanks for the reply! Below I have attached my rhino file and the IES file.
Thanks once again!
trial- square box- 24 sept.3dm (56.8 KB)
66813.IES (9.21 KB)
Hi Amol,
A few things:
  1. You should update your HB installation by using the Honeybee_update_honeybee component as the latest release contains some bug-fixes that Chris Mackey and I had made over the past month.
  2. You need to specify a sky definition to make the simulation work. In your case it will be dark sky as you are only simulating electric light.
  3. I am not sure you can visualize a single point with a mesh. (Maybe you can… Chris , Abraham, Mostapha or Anton can better answer that question).
  4. Your simulation will be in meters. So, I think you should either resize your room (if your original dimensions are in feet) or increase the number of fixtures to get a decent illuminance level.
  5. Honeybee calculates photopic illuminance by default.
  6. I made your simulation work by pasting the contents of your ies file directly into a text panel and linking it to the _iesFilePath. You can also make it work by simply specifying the path directly (ie. something like c:\light.ies etc…).
See the attached file.
boxscript2Rev.gh (527 KB)
Hi Amol and Sarith,
You can analyze a single point but not visualize with a mesh (there is no mesh).
I would try to attach a geometry to the point (sphere, for example), and color it according to the result.
Thanks for that idea! I usually end up just tagging text when there is a single point since I could not think of any other way to visualize it.
Sarith
Hello Abraham,
Thanks for the suggestion! I would try it by attaching the geometry and then colouring it.
Thanks!
Hello Abraham,
Can you please elaborate the idea of analyzing a single point?
Thanks!
