Hi
I’m trying to run a daylight analysis using a sky model where I can input custom Perez sky clearness (epsilon) and sky brightness (delta). I don’t want to use any particular weather file but rather use custom sky parameters.
I was also looking through GENDAYLIT which takes epsilon and delta. But I’m not familiar with how to work with gendaylit through grasshopper.
Is there any way I can create a custom sky using HB/HB+ which let’s me plug epsilon and delta parameters? Or, how do I work with the gendaylit file to input epsilon/delta and use it in daylight simulation using Grasshopper?
Thanks!
