- Solution exception:Failed to load values:
Failed to find probes folder folder at C:\Users\dell\butterfly\case\postProcessing\probes
I’m currently having the exact same issues, is there a solution to this yet?
The Butterrfly_loadprobesvalue components are failing to find the probe folder. It is attempting to find the probe folder in "Users\username\butterfly\indoor_airflow\postProcessing\probes, but I can see that this folder “postProcessing” does not exist. I can see there is a probes document in “systems” folder. I also attempted to create a probes folder to a new “postProcessing” folder.
FYI, I have also done the following:
I have checked many other forums and I can’t find any that have been completely solved or recognised the cause of this issue, unfortunately.
I’m having the same issues too…
It was running well, but at some point it started to fail.
