my PMV/Adaptive/UTCI simulations seems to work fine, every output give me results except the pmv output. I loaded LBT samples to show results, but as you can see in the picture the pmv output give me that error (“Input min is greater than input max”). What does it means?
Ah, it looks like you found an edge case issue. I am guessing that all of your PMV values are lower than -3, which is the default lower boundary of the PMV legend. Let me see if I can recreate it and push a fix.
I don’t know if it matters, but I checked the values in the csv files and some of them also have numbers around -10. Tell me if you need anything, thank’s.
