Possibility of developing Solar Collector Flat Plate Photovoltaic for IronBug
Hey @MingboPeng
I hope you are pretty well.
Many thanks for adding the Electric Load Center components in IronBug, they’ve been extremely helpful. I was wondering if it might be possible to develop a Flat Plate Photovoltaic/Thermal (PVT) collector component in IronBug. This would enable assessment of co-generation of heat and power from the same surface.
I’ve attached an OSM example below for reference.
solar_collector_flat_plate_photovoltaicthermal.osm (429.6 KB)
Thanks a myriad for your support and assistance.
Sincerely,
Behnam
Maynooth, Ireland
Hi @behnammmohseni thank for sharing the sample file. I just had a look, and it should be pretty straight forward to add. I will try to work on this weekend.
Hey @MingboPeng
That’s fantastic, thanks a million for your support and help.
Hi @behnammmohseni,
It turns out it is taking longer than I thought, but here is sample for you that you can use with the newest version of Ironbug released today (Nov 17th).
PVT.gh (81.1 KB)
Please let me know if it works as expected.
Mingbo
Hey @MingboPeng
Fantastic, thanks very much.
I do not know why the thermal side of the PVT is not working; the Generator Produced Thermal Energy and the Inlet and Outlet Temperature of the PVT is fixed at 60, and the fluid mass flow rate of the PVT is 0.
Thanks a myriad for your time and support.
Sincerely,
Behnam
