Hi everyone, I’m about to start learning Ladybug tools and I wonder if I need to have some Rhino and/or Grasshopper knowledge to be able to learn Ladybug? I have some previous experience with softwares like Revit, Sketchup, DesignBuilder… Thanks!
The answer is yes. Rhino is used for 3d modeling. Grasshooper is parametric design. The two is the basic background for using ladybug and honeybee. Grasshooper is a visual programming interface which is very different from Revit, Sketchup, DesignBuilder. You should learn some basic compotent of Grasshooper befort you come to learn ladybug/honeybee.
