Problem: Analysing a REVIT model in the gbXML Viewer
Hello everyone,
i want to have a closer look on my Revit Building. I already exported the model in an .xml. After i put it it in the gbXML viewer, nothing happens. Can someone give me a tip ? Is this the wrong way to generate the .xml. ? Though the gbXML viewer is recognizing the name of my project but he doesn´t show me the building.
thanks a lot!
Fabian
Hi @IBK,
Welcome to the forum! You should at least share your model for @TheoA to be able to help you with the problem.
See forum guidelines here: https://discourse.ladybug.tools/faq
@IBK
By creating the file, you took the first step. We are here to help get up and running.
Can you share the file - so I can have a look?
And which version of the Spider gbXML Viewer are you using. There are several - and each has its own benefits - and issues. :wink:
A had the same problem with Revit 2020 and Revit 2021. When I export my geometry .xmlExemple 3v3.xml (32.6 KB) i miss the slab in Honeybee. Even the model seem correct in Spider.
@Aziz.BOUKARA
Oops, I missed your reply. Sorry. I downloaded your example. It looks good. using: https://www.ladybug.tools/spider-2020/spider-gbxml-viewer/, I see this:
Hi TheoA,
Merci beaucoup.
Thanks a lot.
