@Akaroczkai could you take a look at this?
ARCHICAD 24 INT b3008 still produces the same issue. a simple single zone model with a window/door is enough to reproduce it - the .pln was too big to upload. I didn’t run the simulation with the Energy Model Review panel, others mentioned that without running the gbXML would work fine, it didn’t.
test.xml (67.8 KB)
@mostapha the LBT 1.0 doesn’t (yet) have the Honeybee_gbXML to Honeybee component? it’s only part of the Legacy plugins?
