Problem error import gbXML
Hi, when i try to import gbXML , the component write me this error:
Runtime error (ApplicationException): C:\Git\OS\openstudiocore\src\utilities\time\Date.cpp@448 : Bad Date: year = 0, month = Jan(1), day = 1.
Traceback:
line 254, in script
Hi @domenico, see this: Import gbXML file generated from ARCHICAD
Are you also exporting the gbXML file from ARCHICAD?
Yes, was a file gbXML from Archicad.
I have opened the xml file and have deleted the part of the schedule program profile. Now work fine.
Thanks for the quick reply.
Great! But did you also generate the gbXML file from ARCHICAD? I think we should send them a note if that is the case and ask them to fix it on their end. Cheers.
@Akaroczkai could you take a look at this?
ARCHICAD 24 INT b3008 still produces the same issue. a simple single zone model with a window/door is enough to reproduce it - the .pln was too big to upload. I didn’t run the simulation with the Energy Model Review panel, others mentioned that without running the gbXML would work fine, it didn’t.
test.xml (67.8 KB)
@mostapha the LBT 1.0 doesn’t (yet) have the Honeybee_gbXML to Honeybee component? it’s only part of the Legacy plugins?
Hello Balazs,
I’ll forward this to development to see if anything can be done.
Akos
Thanks Akos, I hope it will be solved.
