Dear Forum,
I have trouble to get a simple apartment set up correctly. I draw in millimeters. The AddSubface component is complaining that some internal walls are not adjacent, but the SolveAdj component says they are.
- Solution exception:Adding sub-faces to faces with interior (Surface) boundary conditions is only possible when both adjacent faces are in the input _hb_obj.
Failed to find innerWallBathroom_1_3ddad690, which is adjacent to innerWallCorridor_2_a0b4d751.
Are the adjacent faces not in the SolveAdj component output? If so, am I doing something wrong on an other part of the script?
I tried several things to get rid of this error:
- changed units to meters, changed accuracy
- changed SolveAdj → it raises an other error, its also in the script
- Solution exception:Number of doors does not match between innerWallCorridor_2 and innerWallBathroom_1.
- changed input surfaces and extrusions to meshes
- tried several different room - door combinations
would really appreciate any help or hints to get going with it. thanks and greets,
Martin
P.S. as I’m a new user, I cant upload the script here, a link will follow:
https://mcbmcb.de/240711-energyModeling-v7-small.gh
P.P.S. I’m working with Win11 and Rhino 8 and the following LB-Tools Versions:
