Hey everybody, it is a really urgent problem. I just used the honeybee_run energyplus simulation tonight and I was told to update the component. However, after i updated honeybee, new problems happened as follows:
This component does not support shading control in versions of E+ greater than 9.0.0.
Use and older version of EnergyPlus or use the OpenStudio component.
The simulation has not run correctly because of this severe error:
** Severe ** Problem in interior solar distribution calculation (CHKBKS)
As I can’t upload the gh file, I attached the screen shot here.
Thank you for your reply. It works for the second problem. However, the " 1. This component does not support shading control in versions of E+ greater than 9.0.0.
Use and older version of EnergyPlus or use the OpenStudio component." stills exists. Could you please help me with that?
Thank you for your reply. I met some problems during removing the current version. I am not sure whether I should remove any files in honeybee. Could you please kindly tell me which files should be remove first before I installed the old version under 9.0?
