Outdoor Microclimate Map.gh (727.5 KB)
It looks like you probably stopped the simulation from running before it finished. Let the simulation run and then you should have a result file that contains the correct data.
Thanks for your response!I have solved this problem.
I have read some book about energyplus,I have not found using energyplus to do simulation about outdoor surface of building.I want to know wheather it is scientific in the examplefile?I am looking forward your response urgently!
