Problem installing latest version of Ladybug
Hi all, I’ve been trying to install ladybug on my work machine for quite and while and always run into this issue, see image below:
At first I thought this is because my IT department blocked python but many of my colleague were able to install with no problem, I was also able to install this on a remote cloud machine, so maybe ladybug has some conflict with software I’ve already installed on my machine?
IT have tried to install with admin enabled but still same error.
Please let me know if you have run into this before and if you were able to work it out, thank you!
Yep, this is because of the policies set by your IT dept.
If you run Rhino as Administrator, you might be able to get this to work but it might just be easier to use the free Pollination Grasshopper single-click installer:
The latest installer will put everything into “Program Files”, which can get around some of these IT restrictions.
